I noticed my 2010 fusion 3L v6 using a bit of oil using 5w20 castrol edge FST 5w20. It within the maks on the dipstick so maybe a 1/4 guart or slightly more. Not crazy but made me aware. Considered a change of brands but stuck with 5w20 edge fst and currently the vehicle has almost 50 grand on it. In my new 13 v6 mustang i used a different brand ultra also in 5w20. Noticed today around 6 grand into the oci that it's also used some but still within the range on the dipstick. Prolly also around a 1/4 quart or it seems more. Will top off and see what it takes to het back to full line. I check both vehicles around an hour after change and both were right at full line after change. Now in the fusion will it make a difference if i go to a 5w30. 5w30 cause it's out of warranty? Ford recs 5w20. In My stang i have warranty left so i'll stick with 5w20 may jump up to 5w30 if it makes a difference in the fusioin. Ive seen here in new 5.0 f150 motors that they are usion oil. Wondering if people have seen this with the new sn oils or is this a ford thing? I understand that using some oil is normal in some vehicles but have never seen it on my vehicles until well over a hundred grand on the odo.
Thanks
Thanks
