XG wii easily do 3 6000 mile OCI
Hey there! Long time listener, first time caller. Regarding the size of the filter in a Honda will largely depend on the climate the car is driven in. The hotter the oil, the more the PSI drops. This is why Honda introduced the small HAMP H1540-PFB-515. Originally intended for Type R's and Type S's, this filter will fit other Hondas as well. At 2.5" tall, this filter is the same size as the Mobil1 M1-108A filter. This will increase oil pressure by about 5 PSI. The importance of keeping oil pressure up in an Honda with VTEC cannot be understated. The Mobile1 M1-110A filter measure in at 3 3/8". This is ideal for cars in climates that see temperatures below freezing. Typically, I'm not a fan of anecdotal evidence. However, I've owned at 2012 Civic Si since new. With 130k on it, I've only every used the smaller filter. Originally the HAMP, but had to switch when it was discontinued. Hope this helps.
I know, right?3 OCIs? You're killing me!
I get them at ($2.70 for the WS and $3.70 for the 3323)
I would go to the dealer and order the Filtech 15400-PLM-A01 filters.
Can't do that anymore.. Honda discontinued the A01 filters.. Even if you do order an "A01" you'll get an A02.. Which is the "cardboard end cap" version filter. Which I think Honeywell makes it for Honda.
