Originally Posted By: MolaKule
Modern GL-5/MT1 lube formulas use what is known as "buffers" or metal deactivators as well as the fact that S-P chemistry contains a special sulfur chemistry that has little reactivity with copper alloys, which is why they have 1A and 1B ratings.
But here is the big question: Why would anyone use a GL-5 rated hypoid differential lube in a car or light truck MT when there is a wide range of dedicated GL-4 rated MTF's specifically formulated for car and light truck transmissions?
I can tell you why I have in the past, it is because my owner's manual says I can use a GL-4 or GL-5 and the stuff I got at the NAPA closest to my house was GL-5. I did tear down the transmission at about 120,000 miles to replace a bad output shaft bearing, and at that time there was no discoloration nor any visible issues with the synchronizers. The bearing failure was somewhat common to this transmission, since then I have not experienced any problems.
Not a reason based in anything other than what the manual said and what was easiest for me at the time.
