Yes. Car and trailer tires. Sometimes it's just to get you home, other times it ends up permanent. I can understand why tire shops won't often do it .
But you're going to inspect it inside, might as well do a patch.When I worked at a tire shop, I never repaired a tire until I inspected it from inside out.
Yea if the tire is safe go for a patch, if the side wall is damaged or if there is rubber shavings from running it flat inside the tire it is trash and no person who actually cares about the safety of their customers would patch it in that situation.But you're going to inspect it inside, might as well do a patch.
If you never had a failure, how is a patch better?Done it many times never had a failure but a patch is much superior compared to a plug. And some locations no longer allow shops to install plugs due to possibile liability issues.
A patch does not make contact with the roadway, it is on a better prepped surface with cement paste, a patch can also work on slightly bigger holes of which a plug cannot work on. A patch can also be used closer to the sidewall compared to a plug.If you never had a failure, how is a patch better?
For me they are always too large, might as well use a real screw that is tiny with rubber cement to match the size of the holeHas any one ever tried a tire repair screw?
