Plugged my first tire the other day using a Slime kit. Other then reaming the hole out which was a beast it wasn't bad.
Discount wanted to sell me a tire instead of patching it because the side walls were scuffed up.
How about you?
Yes he said that is what caused it. I will keep an eye on it for bulges in the sidewall.Plugged many tires over the last 40 years with no failures..
But was your tire scuffed up because it was driven on FLAT?
I have never plugged one of those as the tire structure could be damaged. I just replaced a punctured $220 motorcycle tire that I had driven on flat a half mile or so.
If you drove on it flat and there is visible damage to the side wall the integrity is weakened and you could have a blow out on the highway, this is why they refused and if it were my shop I would have refused as well.Yes he said that is what caused it. I will keep an eye on it for bulges in the sidewall.
When I worked at a tire shop, I never repaired a tire until I inspected it from inside out.If you drove on it flat and there is visible damage to the side wall the integrity is weakened and you could have a blow out on the highway, this is why they refused and if it were my shop I would have refused as well.
The best way, which is what Discount Tire uses, is a patch/plug combination.Done it many times never had a failure but a patch is much superior compared to a plug. And some locations no longer allow shops to install plugs due to possibile liability issues.
