Originally Posted By: eyeofthetiger
Originally Posted By: IndyIan
My tip for a car that has a nervous back end in the snow, like it moves a bit in a straight line when running over patchy snow or ice on pavement, is get an alignment to set the rear toe close to zero... Especially if there is lots of rear camber as well. Don't accept that its "within spec" if the car feels bad... I'm actually surprised there isn't a class action lawsuit for this as its easy to demonstrate the difference in stability.
It makes a huge difference on some cars as they can have one back tire sliding on ice when going in a straight line which is making the car unstable before you do any inputs.
Also I like square shoulders on my snow tires, they help the tire work better as the slip angle increases.
You want toe in for stability.
Yes, why is the car more stable? Because the tires are fighting each other in a straight line, and as you start a corner the outside tire is already "pre-loaded" with some slip angle. Sure, it works very well on pavement where tread block deformation can keep the tread from actually sliding on the road.
On ice though, if your toe angle is too great for your tires to grip enough to deform the tread block, you've got a tire sliding. What happens then? The tire with static grip moves the rear end over until its tracking essentially straight and you've got to let the car make a steering correction, or you'll be turning... What makes it really exciting is often with changing grip levels on each side of the lane, the side sliding will switch on you. My Focus was in spec for rear toe and camber but in the second winter on my snow tires, it just got too sketchy on a partially icy highway bridge as the back end would wiggle so much I wasn't sure I could stay in my lane. I have half decent ice tires too, so its not like I was running studdable hockey pucks...
If you don't believe me, increase the rear toe and camber to the max spec on one of your cars, and see how stable the rear becomes on snow and ice. What works on pavement doesn't always translate to low grip situations...
That's not a fair example. Foci are tail-happy, even on pavement. A typical factory alignment on a typical FWD car is much more stable than a Focus.
What you need to do is toss that control blade rear suspension in the dumpster and mount a n 8.8" rear end back there. A 5.0 V8 fits nicely under the hood.
I know it felt unfair that I was going to get into a car accident going in a straight line over a few patches of ice that should be no issue at all... Fortunately I found a alignment shop that would set the rear toe set near zero, and I have driven happily ever since in any condition.
Most cars don't have this problem, but if you have one that does and the alignment guy says its in spec and there's nothing to do, have him set it at the minimum toe in, and see if it helps.
