It will be ok. But PLEASE don’t go to places like that. Find reputable indy shop.Wife's 2013 VW Passat 2.5 L with 106,000 miles. They used castrol gtx 5w30 full synthetic.
She's had it changed at the dealer in the past. Do I need to change it immediately?
it will be totally fine, the 2.5 is a bulletproof, relatively low tech engineWife's 2013 VW Passat 2.5 L with 106,000 miles. They used castrol gtx 5w30 full synthetic.
Oh I will be ordering oil and filter and going to a local spot from now on.It will be ok. But PLEASE don’t go to places like that. Find reputable indy shop.
Thank you. I will change after 5kit will be totally fine, the 2.5 is a bulletproof, relatively low tech engine
I use conventional oil in my mother in law's 2.5, I just shorten the OCI to 5k miles
Yes before it bursts into flames! You probably only have seconds left by now!Wife's 2013 VW Passat 2.5 L with 106,000 miles. They used castrol gtx 5w30 full synthetic.
Too late!!!! Help. Car now on fire. Water hose or just wait for the rain?Yes before it bursts into flames! You probably only have seconds left by now!
Did you really expect a “Quicky Lube” ton use the correct oil???Wife's 2013 VW Passat 2.5 L with 106,000 miles. They used castrol gtx 5w30 full synthetic.
Please only use VW approved water. If none is available, you can use regular water, but you must wash the car with VW approved soap and water as soon as possible!Too late!!!! Help. Car now on fire. Water hose or just wait for the rain?
Well they aren't going to let you use any water during a drought or fire season!Too late!!!! Help. Car now on fire. Water hose or just wait for the rain?
