I think the reason that it is recommending the use of a silicone oil, is that it has no petroleum distillates in it which could damage the plastic components of the helmet. Oddly enough I did just that on a snomobile helmet some years back. I sprayed a petroleum based lubricant directly onto the hinge and it disintegrated instantly. You should be fine in using the Dot 5 product.
