Cardiobuck
Originally Posted by BMWTurboDzl
Meh. "Ceramic" coating is an aftermarket application (goes to show you what sort of BS people peddle with regards to "Cermaic" whatever). While annoying I would just move on. That hill ain't worth dying on.
I'm not sure what your comment adds. Yes, "ceramic" coatings are aftermarket - he said as much.
Yes, they work and yes, they have value. Yes, they can be scratched and need corrected just as paint would. His may need reapplied.
So you would do what he already did? Move on and come out of pockey to have your paint corrected and your coating reapplied?
Or you would move on and deal with the ruined finish - which could have easily cost $1000 or more?
Why do you think the paint is swriled and not the coating
Technically the paint is not swirled, only the top coat of ceramic is. For the sake of brevity I don't go around saying the dealer damaged a few microns of my ceramic. The look is much the same. That is the point of the ceramic. It takes the UV damage, oxidation, micro abrasions from whatnot so that the paint does not have to. My installer was pretty confident it would not have gone through the most superficial of the coats. Paint correction is all about how much material you have to work with. Without the ceramic you have to be more vigilant to not cut too deep into the paint. The ceramic can act as a sacrificial layer, if you will.
