Slalom44..on your picture that you posted of the clicker valve filter element above, there are two holes showing. Correct? And actually, there are 6 holes in total. Correct? This is in the dome end of the can.
What's inside those holes? I'm suggesting a gasket. That's what i'm talking about.
Some people are trying to push or probe on the bit of endcap where the leaf spring centers. This is irellivent. The hole in the leaf spring is designed to fit on the protrusion from the endcap to center it and form a perfect fit. The protrusion is not there to collapse inward, imho, to make the by-pass work.
How it works is as I described, the oil goes through the 6 holes and forces past the gasket..or clicker. It clicks open or it is shut.
If you look at or cut open a spring type by-pass there is something there in the design to prevent oil from going past. It is either rubber or a composite material in either type, engine end or dome end. Otherwise oil would route past the filter element full time in the by-pass area. Check out pics of other filters with dome end by-pass valves. There is "something" covering that 1/4" hole. Beyond that is the spring which you can see when you look down the center tube. Same thing with an engine end by-pass. Cut open the by-pass sometime..
