2001 Infiniti I30 (Nissan V6 3.0L VQ30DE-K)
4.5 quarts of Chevron Supreme 10W-30 with 3oz Auto-RX using OEM filter
5,464 miles from 14.5K to 20K for 5 months with no extra oil added
Purolator air filter is 4.5K to 10K old
1st oil interval after full 4,500 mile Auto-RX treatment
BLACKSTONE COMMENTS:
Nissan makes very nice wearing engines, and the 3.0L in your Infiniti is no exception. Universal averages show typical wear metals for an oil from this type of engine after about 5,200 miles run on the oil. Your oil was run longer than that and we found all wear reading better than average and in the correct balance to show normal mechanical parts inside. This was 10W/30 engine oil with no gas or anti-freeze in it. The TBN was 1.8, getting marginal, but you could still add some miles to your oil change interval, if you wanted. Try 6000 miles next time.
1st column is current, 2nd is universal averages.
Obtained the car and changed oil/oil filter/air filter at 9K. Was dealer maintained from previous owner. Did full Auto-RX treatment and plan to continue using maintenance dose and was interested getting an easy to remember 5K or 10K oil interval. Looks like dino at 5K is fine. Will try a easy to find a easy to obtain and decently priced synthetic oil around the $3 range and run a report on it at 7.5K after my next oil change. Thinking of the Supertech, Napa, or Mobil 1 ($4).
A good plan or does my oil report say otherwise that I should watch out for?
[ September 24, 2004, 12:05 AM: Message edited by: razel ]
The car runs 45 well driven miles during the work day. 90% highway with cruise at 80 MP. . . ooops 65 MPH and 8 miles of traffic below 15 MPH. During traffic car is kept at a steady pace at RPMs below 2000K without leaving more than two car lengths ahead. Gas petal is floored for a few seconds about three times a week to enjoy the engine or to help keep drivers in their place who try to cut ahead after dangerously speeding and slaloming through the right lanes. Was worried that in the morning the car sees less than 2 miles and 2 minutes before it's on the freeway doing 80... I mean 65, but on it's way to 80... I mean 65 the RPM is kept below 3K. Regardless of the disregard for the speed limit and the defense of the left lanes as the faster lanes, my habits don't seem enough to put me be over the 'universal averages.'code:
Aluminum 2 5
Chromium 1 2
Iron 8 14
Copper 5 5
Lead 5 10
Tin 2 1
Molybdenum 56 64
Nickel 0 0
Manganese 0 1
Silver 0 0
Titanium 0 0
Potassium 1 1
Boron 53 41
Silicon 14 15
Sodium 2 8
Calcium 1735 1952
Magnesium 4 357
Phosphorus 653 787
Zinc 894 926
Barium 0 0
VIS @ 210F 61.5 should be 59-68
Flashpoint 435F should be >356F
Fuel
Antifreeze 0
Water 0
Insolubles
TBN 1.8
