Change of motor oil weight
Florida
My '06 Town Car has 155,000 on it and has never used the tinyist bit of oil. I've used CAM-2 5W-20 100% synthetic in it for the last 90,000 miles but can't find it for sale anywhere. Is there any reason why I shouldn't begin to use 0W-40 Mobil-1 in it from now on?
It's a big jump. I wouldn't do it. Like said, try a 5w30 or any other 5w20. What attracted you to the CAM 2, price?
  • Like
Reactions: pbm
There's nothing wrong with going bit thicker in your climate, but if you don't drive hard enough to get your oil really hot, it's probably unnecessary. Since 5W-20 is working well for you, why not just stick with it or go up to a 5W-30?
I worked for an oil/fuel jobber and met the CAM-2 rep. He knew more about motor oil than anyone I've ever talked to. We became distributors and I began using it. We also sold Amalie and Citgo, but was so impressed with the DAM-2 rep that I decided to use it.
In Florida I see zero reasons you couldn't be running 5W-30 or 10W-30 in that car. You can always find one on sale at Walmart. Maybe this https://www.walmart.com/ip/Quaker-S...-30-Motor-Oil-5-Quart/1671100541?from=/search
You could find a reasonably priced 10w-40 High Mileage oil or even a 10w-30 Full Synthetic. In the south there is no reason for a 0w-XX but yes the 0w-40 should work too.
“…..Is there any reason why I shouldn't begin to use 0W-40 Mobil-1 in it from now on?
No reason not to use the 0w-40. It will work just as well as any 5w-30 in the same price bracket.
You have the 3.9 liter V-8 ? I ask because I have a similar engine to that in my daily driver ‘02 Jaguar XKR ( Ford owned Jaguar during that era). And I’m using the M-1 0w-40 and have been for the 70,000 miles of my ownership. The car now has 185,000 miles total on it. Zero oil consumption.
Z
