I quit using Tearlators a long while back, for this very reason. While it seemed anecdotal at first, it's become a pattern. And these are just the ones we see; what of the tens of thousands that are used and changed out and never cut open by John Q Public? Well never know the true exposure, but what I see from long term Cut-n-posts here is NOT good.
I do, however, have some questions/comments ...
When does this tear happen? I have a theory (no proof, so don't flame me). The greatest amount of force available to tear at the media must likely be when a dry filter gets hit with 40-80psi on the upstream side at start-up, and no pressure on the downstream side (ala fresh OFCI shoves hard and fast against a dry media that has no resistance side the tube. That would induce a LARGE dP. It's likely NOT after many days of use, because if the ADBV is working properly, the dP is minimal with oil on both sides of the media. Therefore MY THEORY is that these tears happen almost immediately. So essentially the entire OCI is run with a compromised pleat resulting in a leak path. The only other time it might happen is if the ADBV is failing repeatedly, so that this large dP happens daily, and the repeated cold-start pounding finally tears the pleat from it's adhesive.
That in mind from above, how much "flow" is seen going through the tear point? That is VERY hard to estimate, and would only be revealed in some very elaborate testing in a lab. It's an answer we'll likely never get.
But ... and this is what I've been asking about for years ... how much does this matter?
I'm not in any way happy about a media tear, but the engineer in me wants to know the true effect in a measurable sense. It would be great if we could get some UOAs to go along with these "tears", to see if we can find any correlation of wear increase in a substantial manner. Undoubtedly no person will advocate that a tear is a good thing. But how much of a bad-thing is this really? Conceptually we all cringe at this. But what is the real world willing to reveal to us?
Is a tear good? No way.
Is a tear bad? Probably, but by how much?
Really bad? Mostly bad? Somewhat bad? Barely bad? Hardly discernibly bad?
PLEASE - the next time someone posts a "torn media" filter thread, can we get some UOA data that coincides with the OFCI, and we can start to build a knowledge base around this topic?
