Originally Posted by RayCJ
I hope the OP is aware that there's a small band-steel retaining clip that needs to be pushed out of the way while loosening the cartridge cap. There are plastic notches on the cap and when it's tightened, the strip of band steel presses up against the one of the notches to (presumably) prevent the cap from unscrewing from vibration.
Put the filter cap wrench on the cap, use a screwdriver to momentarily pry the band-steel spring out of the way and then, unscrew the wrench. As the cap unscrews after a couple turns, the band steel will no longer be in proximity of the plastic tabs on the cap. -And yes, I agree, it seems totally unnecessary.
I found this out the hard way (just like are) on my son's Corolla.
Ray
If I'm not mistaken the Motivix brand tool holds the steel band out of the way. The one from Amazon looks almost identical to my Motovix at half the cost.
Ray
