AUC, or Area Under Curve is what matters here.
The theoretical engine in question would make 1500 lbs ft at idle, and continue to make 1500 lbs ft all the way to its 20,000 rpm redline.
One gear does it all, if the engine is flexible enough.
Again, it's only the deficiencies in engine design that necessitate gears.
Get real. You have just described an engine that makes a peak power of 5712 HP.
The Devel 16 makes a peak of 5000 HP, so it's hardly unrealistic. besides, nobody said anything about realism until AFTER I described the curve. Unfortunately I'm not a mind reader.
However, the point remains that a sufficiently flexible engine doesn't need gears.
Can you disprove my assertion?
I don't have to. I'm still waiting for you to post the torque curve of the engine that will match the ZL1's performance with a single gear ratio in the drivetrain.
imagine, if you will, a strait line. It remains straight from idle to redline, whilst maintaining a constant 1500lbs ft. Redlines at 20k. 4 wheel drive, cut slicks, gross weight 850 lbs.
Any questions?
