If there is metal to metal moving contact, I lightly lube those points with a high temp. grease..i have done many brake jobs on cars . i usually lube the ears . but watching SMA and a few other channels they install them dry. also, never seen lube used on cars from the factory .
So what do you do ,lube or not lube?
I guess the trick would be holding Mom still.I’ve done it both ways, honestly I don’t think there is a right or wrong way with either. Right now I’m nit applying grease on top of the clips and ears, but under. Doesn’t matter, when I go to change them again, the rust has still built up under the clips. My advice, do what you want, there’s so much water and salt that gets washed up into that area that nothing will prevent the inevitable.
I once took a brake grease class (I’m serious), and of course it was put on by the brake grease company - and they directed us to apply it to everything, every darn surface imaginable. If my mother walked in, they would have told me to cover her in grease too.
been my experience that most modern disc brake setups also have replaceable hardware which is really inexpensive.i have done many brake jobs on cars . i usually lube the ears . but watching SMA and a few other channels they install them dry. also, never seen lube used on cars from the factory .
As mentioned before, your climate changes your approach to subjects such as this. For me, greasing the ears would only attract brake dust and make an unnecessary mess.
