Originally Posted By: WhizkidTN
Originally Posted By: edyvw
Originally Posted By: another Todd
Despite being adamantly opposed to buying a direct injected vehicle until they figured out intake valve carbon issue...my wife really needed a new car and wanted a Ford Escape, so rather than buying the anemic 2.5, I opted for the 2.0 Eco-boost(she is a sporty driver) knowing I would face these issues down the road.
My question is: would using an oil with the lowest possible volatility rating automatically cause the lowest possible intake valve deposits?
My dealer says they do BG intake cleanings on these engines "all the time" and have no issues but I thought Ford says the intake cleaning by that method destroys the turbocharger; so I would rather avoid the issue in the first place.
I would ump those ILSAC GF-5 oils and went with Euo oils since they have lower NOACK.
Since that engine is specd. for lighter oil, I would not go above 13cst, so M1 0W40 FS with 12.9cst and HTHS of 3.6 would be good option. Maybe even better option would be Castrol 0W30 with cst of 12.1 and HTHS of 3.58. NOACK on those oils is very low and they are proven in much more demanding applications. I used nothing but Castrol 0W30/40 in my VW's and M1 0W40 (not as much) and never had issue with 2.0T.
Also, since you are in CA (low Sulfur in gas) you can try Mobil1 5W30 ESP. It is Low-SAPS oil. You not only need low volatility oil but lower SAPS oil. M1 ESP has NOACK of 5.6%, HTHS of 3.58.However, do UOA after 3K to see where is your TBN and TAN. I run it once in my previous car, VW CC in 2.0T engine, and TBN was at 2.1 after 3K, compliment of DI and high sulfur gas. However, CA has lower sulfur in gas, so it might work. You have M1 in NAPA sometimes on sale for $5.99 a liter, otherwise it is $109 for 12 liters on Amazon.
Do you have any info on the M1 Euro 0W-40 FS oil NOACK? What about the Castrol Edge Euro 0W-40 oil?
Not sure about M1 0W40 FS since it is fairly new mixture. Old VISOM had 8.7%, so since FS is GTL it could be less.
Castrol 0W40 is 9.1%.
