On the UPF64R vs. PF64 issue, there is a difference in bypass valve design and the UPF64R uses the superior silicone ADBV. They were cut open here:
https://www.corvetteforum.com/forums/c7-...ilter-pics.html
Bypass pressure on the UPF64R is 35 psi, and the PF64 is unknown (can't find it). I did notice the 2017 Malibu Owner's Manual (OM) does insist on the UPF64R, so you are wise to stick with that one exactly. In contrast, my 2018 Equinox OM only points to the PF64, which Fram says cross-references to an XG10060 with a 10 psi bypass.
Also, Fram says a PH12060 with a bypass of 25 psi, will cross-reference to a UPF64R if you can trust them. I'd choose a UPF64R over the PH Fram in your case.
http://www.fram.com/Search-Parts/Part-Detail?PN=PH12060&CP=UPF64R
Filtering comparisons: Fram Ultra has better filtering efficiency specs than the PF64 or UPF64R, so breaking mine in with an Ultra should work OK.
I put on a magnetic drain plug to catch more break-in iron (GoldPlug AP-04 there).
