Last time I did it I went 50/50, which I believe is a lot more syn than you're going to get in most over the counter blends. It worked well, I used a Mobil 1/Mobil Super 50/50 blend...I believe the Super has a bit of low grade synthetic in it anyway so it was probably over 50% total.
That same vehice currently has Rotella T5 with a top off of Platinum in it, I guess that would be a blend also, not as high of ratio as before though, mostly because the T5 is had in a jug and I don't like to use partial jugs.
Blend away!
