Originally Posted by BrocLuno
Originally Posted by Jarlaxle
Originally Posted by Silverado12
Sportsters are nice bikes. You can dial in the suspension with Progressive drop-in springs for the front and new shocks for the rear and make it ride really nice. That looks like a 1200Low, but I would install longer travel springs that will give it a little more travel, but raise your height off the ground. But anyways, rough ride is the most common complaint w/Sportsters.
It's actually an 883 Super Low.
My last one was an XL1200C which is equivalent to a "Low". I did not care for the short harsh shocks and forks. So it got 2" over tubes up front with much lighter fork oil. And longer rear shocks (a used set of S shocks provided the ride height calcs). Meant changing the side stand, but they are readily available on the 'Bay.
Most Sporsters have a low seat height. The Low and Super Low seems to me fashion statements and are good for bar hopping, not long cruises ... I have a 29" inseam. Standard height Sporty's seem fine, and I considered adding some additional suspension height ... I would for sure for an off road version. But to long a rear shock gets into belt tension issues and may mean conversion to chain drive - not something I wanted to get near. The belts are great, just don't run them too tight ...
Actually, no...the Custom is very different. The Super Low has 17" radials, ~4" riser bars, and mid controls. The Custom has spoked wheels with bias tube tires (19" on older models, a fat 130/90B16 on newer ones), forward controls, and lower bars.
