Originally Posted By: mightymousetech
Originally Posted By: FordCapriDriver
I think that it would be a good idea as long as it only was activated when the engine is warm, it' can't be good for the engine to be constantly shut off and started again in cold temps, also warm up i imagine would take much longer.
These systems do not activate for several reasons, on the Acura system, all of these will turn the system off:
-engine not up to operating temp
-very cold temps
-A/C on/defrost on
-battery low on charge
-drivers seat belt not being used (this one surprised me)
There are actually about 12 different conditions in the data list that will prevent the system for activating. Pretty much has to be ideal conditions to activate, which for here in Ottawa, only happens in the spring/fall. We get lots of complaints about the system "not working" in the winter, and in the summer when it gets hot.
If the engine is warm, you are not doing any extra harm to the engine by shutting it off for 10-30 s are restarting, all critical components are well lubricated. The only thing these systems is hard on is the battery and starter motor. On our cars with start/stop, Acura uses a larger capacity AGM battery, so would not really worry about it.
Do they spec a better starter verus prior years without start/stop?
