I have a 02 Buick Rendezvous with almost 169K on the clock. I purchased it at 160k, it is the AWD vers-trak with the 3.4 v-6. The ATF is a slight brown color. It does not smell burnt but I have no idea how long it has been in use. Prior fluid would have been Dexron 3 I would assume. No prior history on the vehicle. Shifts well and acts like it will last a long time. I am going to do a full system flush and refill. Should I go with the new DEX 6 or stay with the old DEX 3. My concern with the high miles if it has lasted this long on DEX 3 than if it is not broke then do not fix it. Or is there anything to be concerned with the DEX 6. I know it is more shear stable with better cold flow properties.
