I bought a little beater Saturn ion quad coupe. One issue that seems to be perplexing is the stereo picks up this annoying whine through the speakers as you drive. Definitely like alternator interference. The stereo when I bought the car was an aftermarket stereo but didn't have Bluetooth I swapped it out for a modern aftermarket radio with Bluetooth. Both stereos had the same issue. The radio is so small adding a ground wire to the case would be a challenge. I have read the ground could be the issue? Is there anything else I could check that would cause this? It's an 04 ion quad coupe
