JAG
Thread starter
After the above pictures, 2 drops of water were added to each oil cup, then the oils were heated to between 115 F to 200 F for about an hour. The water drops remained at the end of the hour but some of it evaporated. The drops remained quite clear in the M1 and murky-looking in the Amsoil, indicating more miscibility with the Amsoil. The water caused some white fallout to occur in both oils. This is known to occur due to some additives reacting with the water, and falling out of solution. It's not a good thing but it happens. I didn't take photos of that but I can still take them if requested.
After that, the steel blocks were cleaned and dried, then a layer of walnut oil was put on each block, then 2 drops of each already tested oil. The following pictures are from after heating them up to as high as 300 F for an hour.
