Originally Posted By: danez_yoda
Did you premix the 10w and 5w oil before pouring the in the engine? If not it was the 10w and 5w oils wrestling with each other and knocking sludge loose like a couple of teen age boys in a sheetrock room.
I thought M1 was a good cleaning oil but i guess not. I have seen posts of people claiming that the first time they used pup after running m1 their oil turned black fast.
Might have been varnished up real good and is just getting cleaned.
Oil colour means next to nothing. Certain additives change colour when exposed to heat which will rapidly change the appearance of the oil. Reactions with combustion byproducts can also yield the same effect.
Given the OP used an additive, that throws any theories that could be tabled about the differences between the two lubes out the window, as that's another variable in the mix.
Agree - both that Amsoil clean well and color means next to nothing.
Amsoil recommends NO additives so that could be part of the color issue since OP's test didn't include heat testing the additive.
JAG, I wouldn't run the SS less than 5000 miles even if it was mixed with other oils - and might even take a UOA at that point to see if it can go further. This IS a long OCI oil after all.
