Help choosing oil viscosities
Another vote for Restore and Protect. 5w30 for both. The Acura will benefit from the thicker oil, slowing burn, and hopefully, the R&P will clean the rings and reduce oil consumption also.
  • Like
Reactions: wlk
Valvoline restore and protect with top tier gas may clean up a ring sludge problem then it may seal better. If that doesn’t help it, I would dump in a quart of the non synthetic Lucas oil stabilizer. The naysayers on here do not like it but it does reduce consumption in old engines.
Of course it can. But that’s not the debate, the question is why dilute the oil’s additive formulation with a product like Lucas? Why not just use a thicker formulated oil instead?
Lucas thickens the oil for sure. But it’s only unadditized cheap stock, thickening the oil is all it does. The rest of what it does is a negative.
Since you like M1 and like EP and 10W is good enough for the given temperature range, plus my much older v6 Tacoma doesn't burn any oil with it (whereas it does burn with 2 or 3 different other oil I've tried) ... I would give it a shot.
However, it may not resolve your Acura issues and/or win the cup test.
Which V6 do you have in that Tacoma? Not too many oil burners in old Tacomas.
I think it's the 4.0 V6 1GR-FE. It doesn't burn oil or have any problems as far as I can tell.
That's a great engine. Sorry, I think you said it burns oil with a few brands above. Did I misunderstand that? Which brands did it burn with?
Sorry for any confusion. I have reason to believe the Toyota does NOT burn oil, until I see otherwise. Acura consumes 2qt/3k currently with M1 EP HM 5W-20, and that engine has a history of ring sludge problems (probably due to transmission tuning changes shortly before and the engines being lugged constantly). I plan on doing a piston soak with HPL EC30 and a good Italian tuneup after that.
Not a bad plan. I’m sure they appreciate it. I would make strong consideration to Valvoline Restore and Protect after that.
  • Like
Reactions: wlk
This is the logical starting point for engines with significant usage before they come into your care.
This oil in this viscosity is a nearly ideal "when in doubt, do this" for almost every gasoline powered vehicle.
Once you are confident it's clean and not burning oil, use something else if you wish or stick with the VRP.
I had some nice 5w30s in my chest freezer, and it was an eye-opening experience.
At -15C, Idemitsu 5w30 was hard to pour out from the container, Valvoline Restore and Protect 5w30 was like molasses but slowly flowing, and PUP 5w30 flowed nicely like ESP 0W-30. All 0W-20 were super easy to pour out from containers (maple syrup viscosity).
Starting sound of my Subaru Outback with Idemitsu 5w30 was not nice at all -20C.
I prefer 0W stuff for such a occasions.
Try Mobil 1 Truck & SUV next, PUP will be beat.
