Amsoil now recommends Subaru's 3,750 mi. turbo OCI
I'm not sure how this is an oil issue. If this is the screen I'm thinking of, it's the pressure side inlet of the turbo. Any single or dual ball bearing turbo requires this screen. Aftermarket manufacturers won't even provide a warranty unless you buy a new filter with turbo purchase. With the older journal bearing units they weren't necessary.
If it's just regular debris that's plugging filters, maybe it's time for an EAO to assist.
Originally Posted By: bluesubie
Gary - There's actually a pic in the "TSB" link in my original post. I could probably find another one with some searching.
-Dennis
You are not logged in or you do not have permission to access this page. This could be due to one of several reasons:
1. You are not logged in. Fill in the form at the bottom of this page and try again.
2. You may not have sufficient privileges to access this page. Are you trying to edit someone else's post, access administrative features or some other privileged system?
3. If you are trying to post, the administrator may have disabled your account, or it may be awaiting activation.
Originally Posted By: Gary Allan
That is, something like an "umbrella" inserted into your (hmm) aorta (?) to catch blood clots to prevent pulmonary thrombosis.
Gary,
That's inferior Vena cava, not the aorta. This is probably the only time I can correct you on this site! You know way more about oil than I...
Gary,
Sorry ...some of my copycat rhetoric erodes in the chemical electrical suspension.
Dennis,
I'm still here, just a bit busy at work lately.
Yes, I'm still running the Rotella 10w30. Someone else in this thread questioned the need for a Synthetic for a 3750 mi. OCI. I agree. Also, when Mr. Dyson recommends an oil over GC for a turbo Subaru, I listen. :-)
TeeDub,
7500 miles was certainly fine with a good synthetic in my '03 WRX, but, the 2L engines don't have the screen. I understand that this screen was added in part for the variable valve timing on the 2.5L engines.
Ed
-Dennis
Oops, sorry. Try this pdf Dr. Allan.
-Dennis
-Dennis
-Dennis
Thank you. I wonder why it required a TSB
That is, the designer of the screen didn't see a need for PM of this item ..for whatever reason. Hard to imagine that it would be an oversight. One would think that this would have been endurance tested to a very stressed level before releasing it to the market ..given the capabilities of the engine.
