Looking for an expensive replacement convertor. The "y" pipe rusted away on the original and the noise is bothering me. I found these two on eBay. Assuming they are the same cost, which would you go with? The first picture looks like it uses a seperate y section, where the first looks like the pipe is just spliced in. The negative I see on the first one is that it comes and a RH and LH side along with the rear pipe, which is fine I guess, but to me less connections are better than more. Opinions?
