Alignment Specs '05 Lexus LS430
VA
I got my LS430 aligned today and when I got home the tech used the specs for "Air Suspension" which mine ain't. How can I find out if the alignment specs are that much different between coil springs and air?
If mine are in spec, I won't bother going back.
From when i worked at a Lexus dealership there isn't a difference in the alignment. Some mentioned camber but the air ride kit should adjust that with the height
I'm not sure how much different they are, if at all, but most Toyotas don't have adjustable camber. Usually, only the toe is adjustable
I just installed a shorter rear control arm to try to bring my rear camber into spec. Lexus has 3 different lengths.
