Originally Posted By: Hootbro
Originally Posted By: ZeeOSix
You missed the point, which was if the oiling system is so sensitive to what filter and oil viscosity is being used, then it could very well be under designed. Maybe the oil pump is really weak in these engines and the pump goes into bypass/pressure relief mode way too easily. Or maybe some of the oiling circuit is already too restrictive and therefore very sensitive to any filter and oil viscosity changes. No, the car manufacturers do not design around aftermarket filter manufacturers ... but if they were smart at least they should consider as part of their design criteria the range of possible filters that could be used on that particular engine.
First of all the point your are trying to make is an assumption. Without being on the engineering team or access to proprietary data of what their start and end point in the design was, to say they "under designed" is conjecture at best.
Absence of fact does not make the supposition.
Just sayin' ... an assumption with some possible validity it. You don't really see many similar TSBs from all the car makers ... except for maybe Nissan (weak oiling systems too?). Seem a little sensitive to the issue.
