5W20 Under 45 Degrees F. ?
Say you live in the PNW and your air temps have a limited winter range (20 degrees F. to 45 degrees F ) for suburban driving conditions. For a Kia Seltos 2.0L non - turbo MPI engine - do you just stay with a D1/Gen 3 5W30 or drop down to the same in a 5W20 (or even a 0W20 ?) for 6 months / 4K mile OCI ?
Best question so far. What does the owners manual say?
If it was mine I’d say 5w30 QSUD and forget about over analyzing things.
Some of those aren’t actual SAE grade designations, and an appropriate winter rating is determined solely by the starting temperature, not operating temperature.
Just for fun! I always read the owners manual then for winter summer recommendations,I’m retired
Regardless of the pour point, no oil with a 5W winter rating will have better pumpability and cranking performance at very low temperatures than an oil with a 0W winter rating.
But here with 20F given as the lowest starting temperature there will be zero significant difference between either winter rating.
That's all true. However, if I lived in the PNW, I'd make winter trips to remote destinations where temperatures could easily get quite low.
In the Seattle/Portland area, there's no reason at all to go thinner than 5w30 if that's what your car calls for. It just doesn't get that cold here. 5w30 is pump-able well below zero degrees Fahrenheit
5W30 is allowed for both my Kia / Hyundai vehicles in my sig (although the oil caps of both are stamped “5W20”). Interesting to note that unless you drive I-5 or I-405 it’s just one connected neighborhood after another driving at 35 MPH the whole time . I see my share of vehicles that once they accelerate will burp up a noticeable cloud of brown smoke which I attribute to a lot of slow suburban driving with shorter distances . Severe Service OCI at its best !
. . ."Last I read, he was entering around 210,000 on his odometer and the engine hasn't been replaced."
Why would that be considered "newsworthy"? The vast majority of H/K engines have not been replaced and will continue to give good service until they're scrapped for other reasons. Pick any vehicle brand that's mass-produced and I'll show you statistically significant engine failures in their history.
I e learned to not believe or listen to what tripleseven posts. It’s all opinions, no facts
As I said previously in this thread...I'd stick with 5w30 in the OPs situation.
Since there is a lot of discussion about 0w20 vs. 5w20 going on here I'd like opinions on using 5w20 synthetic
in my daughters Mazda which specs 0w20. Reason being I have some 5w20 Pennzoil Ultra that I'd like to use.
In my neck of the woods single degree Fahrenheit would be the absolute coldest encountered and that would only be a few times a winter. In the teens and low 20s are the morning norm. Would 0w vs. 5w make any difference at those temps?
For what it's worth my daughter rarely does any short trip driving....she usually drives a minimum of 20 to 40 miles each time she starts the car.
In my neck of the woods single degree Fahrenheit would be the absolute coldest encountered and that would only be a few times a winter. Would 0w vs. 5w make any difference at those temps?
Nope, nothing meaningful until you’re below about -30 or so.
