Be sure to slightly open the oil drain plug ,
with a clear open container under, to make sure only oil comes out; any WATER that may have made its way into engine over the years (thru carb, etc) will settle in oil pan at bottom, and come out the plug FIRST, letting you know if that will be an issue. Should come out clear and obvious water (since engine hasn't been running to churn it all together) Drain and refill with cheap oil if there IS water.
I have had luck freeing an engine (when crank bolt doesn't work) by manipulating via the FLYWHEEL teeth! I took cover off down there, then used tire-iron that fit well inbetween teeth - was able to pry back AND FORTH ( crank bolt may only let you go ONE way before it LOOSENS). Careful not to break any teeth off; try one direction first (without over-doing it), then reverse. I found that the reverse direction free-ed it up (because it was already jammed forward by the starter).
Good luck, and be sure to report back!
