What is the name/model for this neat red brace ?
How are owners supposed to jack up these cars to replace a flat if they don't have jack points?The stands shown are designed for the pinch welds at specified locations that I have found newer vehicles don't have. even id they do, seems the pinch weld will collapse.
A clever fellow could fabricate a cross bar that spanned a pair of these $20 jack stands and get the same functionality. That’s assuming there’s sufficient room between the jack point and the wheel, of course. And also assuming you trust your life to your welding skills.Many of them have only one spot on each corner. My jackstands double as lift points so not an issue for me.
Link to jack accessory (the red thing) please!Many of them have only one spot on each corner. My jackstands double as lift points so not an issue for me.
It’s posted in #23 above.Link to jack accessory (the red thing) please!
You could easily make a non-adjustable version of that from a piece of square tubing with a couple of notches ground into both ends.Just showed up in my facebook feed tonight
Jack Rod Stand – AGA Tools
Increased safety & stability. The AGA Jack Rod Stand is the ideal replacement for a faulty jack stand. Great compatibility. Secures floor jack while being used!agatools.com
