Your engine is very new. Were you measuring a high oil level at any time?you mentioningCan condensation occur enough to have 5.1 quarts at 1k miles when 4.4 is max?
It’s also interesting how someone on pg2 drives 3 miles to work with a hybrid and has nothing under the cap.
extra oil volume requires additional explantation.
In the winter the engine will kick on earlier if I am demanding heat for example. Let the engine kick on and turn the heat down to 65 for example and pit the pedal down if the traction condition’s allow. The best way to heat up oil is engine rpm not load.
