GON
$100 Site Donor 2024
2019 f350 4wd just bought, truck gear shift is in park, yet display is showing truck in drive"M". Can't move the lever, can't start the truck, anyone have any knowledge on this?
The manual shift mode is engaged. You will need to install the console and use the rotary knobs center "M" button to disengage. See video.
Further update, truck is actually in neutral but shows in gear. I think Pimtec is on to something the trans release has been used,, but the tow truck driver doesn't know so off to the ford dealerWill it remote start if so equipped?
Are the brake lights working as @97prizm suggested?
I had a problem that gave the same message with my wife's 2019 Pathfinder some months ago. It was the stop lamp switch. The 2019 pathfinder still uses a mechanical / cable actuated floor shifter, which I'm assuming the column shift on this F350 is.
This might help with your stuck shifter:Further update, truck is actually in neutral but shows in gear. I think Pimtec is on to something the trans release has been used,, but the tow truck driver doesn't know so off to the ford dealer
Yes, worked flawless after cable hooked up. Wish the tow driver would have known to check. I gave the service writer a Benjamin to have someone look at the truck just for a second he gladly took the Benjamin but told me next week. So I just started looking myself. I have a flight out in a few hours, so I had to gear up this being a Friday afternoon, record heat, and nobody is going to want to help me. So I played everything conservative. But it all worked out. I drove the truck to the airport, in a Uber now to go get the rental car. Then get on the road and cancel the flight.That’s what I was going to have you check @GON, it sounded exactly like the cable had come off the ship most likely done by the tow truck driver to get it to the auction
Were you able to get the truck to show the correct gear position once you hooked the cable back up?
