Originally Posted By: ARCOgraphite
Wife has a new 17 ( see my sig) No oil burning on this engine. It is NOT underpowered unless you are boy racer - and then you picked the wrong car. It is silly over priced for a tarted-up Impreza wagon.
The CVT works very well, it has a tiny torque converter that locks up immediately so you don't have the slush box effect from the saucy converter pumping losses. Not as nice as a dual clutch (PDK) but likely more robust.
The base forester is still the sweet spot for most car for the money.
When my wife was "bargaining" for the new Crosstrek, I sat in a new impreza.
There is now room for a six footer plus, though I find it curiously non-Subaru-ish. Redesigned Interior could be from a Honda Civic.
Main thing I notice wrong about the current crosstrek is also what was wrong about the base forester. Unrefined springing and damping. The rear is soft and bouncy on the crosstrek as if the compression damping is dialed way wrong on the soft side. On the forester the spring rates are silly-high and the compression damping is high also, resulting in a buckboard, nueck snapping ride. Unacceptable.
My cheap '14 Rogue Select has better seats, driving sightlines and ride.
The Crosstrek is on the all new Subaru Global Platform though that Subaru spent over $1B to develop. This has ridiculously high leaps of improvement, like claims of 50% or 70% or 100% increases in particular chassis metrics. Usually a new generation will only have like 15% or 25% improvements, so these increases are huge and should be highly noticeable.
So comparisons to the current or older subarus not on the global platform are not applicable. The only exception is the current new Impreza which was the first on the Global Platorm.
Anyone looking for a Forester or Outback should wait until those cycle through to the new platform as well, at least to see the improvements.
That being said, because the gains are so huge, there should be clearances on the older "obsolete" models as they roll off the production cycle as shoppers who did some research would have gotten the advice to wait.
