Originally Posted By: Artem
Originally Posted By: dblshock
I can't imagine what a 0/20 UOA would look like after 12k/15% OLM up in the cold, 3-4 rounds of that and wear issues would become clearly noticable.
I couldn't agree more. Long term engine wear is what matters, not short term UOA results that is clearly showing this NEW engine isn't running as efficient as it should be and although it SEEMS to be handling the fuel dilution FOR NOW, once the anti wear and anti friction coatings are washed off the engine internals, wear rates will increase as the engine ages and I can't see this being a happy engine after 200k+ and 10-15 years of use.
Older Honda engines from the 90s seem to be healthy and run good. The same can't be said for these engines in 10 years if the fuel will cause excessive wear. I can picture these leaving a cloud of smoke at the intersection because the piston rings are shot and the turbo is failing because it's being lubricated with fuel and not oil.
Honda clearly wants you to buy a new vehicle once your warranty expires.
You keeping this thing for 10 year and 200k+ does them no good. They need sales. Hahaha.
Yep, not your mothers Honda engines any longer.
