just drained the factory fill from a friend's 2007 Range Rover Sport SC. 500 miles on the factory fill. he wanted to change it before a 4k mile road trip out west.
Tried to use an oil extractor to avoid dropping the hefty undercarriage tray -- only got 3 quarts out (8.5qt capacity).
So I took the tray off and pulled the plug (btw, same drain plug as my dad's 1998 Grand Marquis). first 6-8oz of oil that drained looked like dirty water, not motor oil. I actually stopped the flow, thinking I had pulled the wrong plug. the rest looked like regular drain oil.
the pan has a small, narrow, low section that dips down far below the rest of the sump. this is where the drain plug is.
I'm wondering if the oil pick up does not reach down there, and the oil basically sits and stagnates (not that it should ever look like water, though).
also (rant)... the drain plug faces front, so you get a strong horizontal stream of oil that plows into the back side of some kind of metal canister, where it then proceeds to splash out in every direction making a huge mess. why on earth would they do this? it would've been so easy to point it downward.
other than the stupid oil pan design, I love the truck. 390hp supercharged engine and handles like a sports car. he says it gets 8mpg.
