Rovers run extremely rich. You will see a lot of fuel dilution. I would not reccomend extended drains on this engine. 3-5K Max.
Quote:
The engine is a 1950's Buick Design that has been modded over the years it is not a BMW Engine. They have used the same block and punhed it out from 3.9 to 4.0 to now 4.6L
Quote:
Quote:
I did just that last year....dropped $70k on a BMW truck and left the factory oil in for 7.5k and hence the observation that changing it out at 500 miles (1.5 fuel fill-ups?) is a complete waste of time. Nothing hostile, just my observation.
5k miles would have been completely fine too...especially in Euro. engines with high capacity, cleaner combustion, better quality engines, better filters, and A3 oil requirements.
Now, the real questions we should be asking are: Did the witches brewof oil used meet Rover's specs? Do the 4 different brands used together have any mixing/addative clashing issues now or down the road? Does Rover spec. A3 5-30's or any A1 or dino (non-ACEA rated) 5-30?![]()
Again -- did you cut open your oil filter? did get a UOA? then how do you know it was fine? your opinions are based on conjecture & the direction of an OEM looking to save money on its free oil service, nothing more. go look around for BMW factory fill horror stories -- there are several on this very board.
And from what I've seen on the 3 series, BMW does not specify 7.5k for its factory fill -- they go by the oil life computer, which in the cases I've seen will not indicate a change until well past 15k miles, by which time the filter is completely clogged and in bypass, and wear is off the chart - all at the direction of BMW and their "free oil service". are you saying your truck is different from other BMWs? and just "happens" to be the same 7.5k that LR specifies?
and you are still avoiding the observed watery liquid -- according to you he should've just left that in?? real smart.
and the "witches" brew, as you call it, far exceeds LR's spec of dino 5W30. heck, they specifically recommend "Castrol 5W30" - no mention of synthetic, but even Syntec 5W30 is not A3 rated -- again maybe you missed this in the same post where I described the "witches brew". good grief.
and all modern oils are designed to be compatible. "additive clash" as you call it is a myth you read somewhere online that has no basis in fact with modern oils.
oh, and BTW, I'm not sure where you're from but calling someone a "waste of brain cells" is, in fact, hostile. and now I'll be a bit hostile -- get a clue, and support your opinions with fact/data or keep them to yourself.
Quote:
they don't have Syntec in Europe. And there are different types of 5-30 (eg. A1 vs. A3). Which is the correct spec.?
Quote:
...Can you do a UOA on this mix and derive anything from it not knowing the final product or viscosity?
Quote:
...A far cry from 500 miles...changing your oil (new or otherwise) after 500 measily miles is a waste of 8.5L/qts. of oil...
Quote:
..I was NOT being hostile at all...
Quote:
excuse me mr. nick, but I was not the one who started the hostilities, and the "waste of brain cells" comment was way out of line and not appropriate for this forum, especially since the foreign substance had already been discussed. perhaps you should mind your own business, instead of sticking your nose where is doesn't belong.
Quote:
I suppose in your mind this was not a hostile, mean, bossy reply to me. Do I have to check with you from now on to see where my nose belongs before I am allowed to post on this forum?
Quote:
Why didn't the engine hydrolock? Also, would moisture really accumulate that much. Geezz, from the way you described it, sounds like alot of water.
Maybe someone poured a cup of water down the fill tube as a bad joke?![]()
