Hello everyone I have a 2003 cummins that has no egr components or cat on it as well.
It has 176k miles and I am wanting to extend the oci to 10k if possible, I will be using a dbl 7349 for the first time so I will be running that for 3k miles with the new delvac 15w40 I bought today from walmart. I have never used a low micron rated filter like this which is why I am doing a 3k oci.
I was planning to use T6 15w40 with the DBL filter and go 10k if possible, or would the delvac 15w40 work as well?
Is this a good route to go for the future or should I do a oil sample after my 3k oci with the donaldson filter in it? I want to do the 10k oci so I can also change the fuel filter at the same time so its less work, thanks!
Here is the filter and the delvac oil that I bought today from walmart for 10.97
