Originally Posted By: youdontwannaknow
Friend's 2001 Camry 4-cyl started hesitating while driving and then just stalled and won't start. CEL is ON and DTC P0300 (random misfire) is set. Car was towed to dealer. Dealer says will need to replace ECU, all 4 injectors and plugs. Bill = $3500.
Sounds like they're trying to rip your buddy off big time. ECU's rarely go bad, especially Denso units, but regardles they probably want to charge you to change it, and NOT change it. Who'd be the wiser?
Quote:
Does that make any sense to you ? Is this possible ?
No sense, highly unlikely. As said, it sounds like a possible vacuum leak or just worn ignition components. UNLIKELY it's the Injectors........ go to another shop! These guys seem like they just want to 'replace' a bunch of parts and cross their fingers that it solves the problem, as usual.
