Originally Posted By: SubieRubyRoo
Personally, I haven't used and won't use the Mercon. I haven't read anything that gives me enough confidence in that fluid- I would use Maxlife before I used Mercon LV. JMHO.
We're under ford's ESP warranty for 7 years or 125,000 miles and we have just about 20,000 miles on it now. And the Explorer is just 1 year old. So I'm going to stick with the Motorcraft Mercon LV at least until the warranty is over. I did the first drain and fill at 12,200 miles and will do the second when the odo is at 25,000 miles then every 25,000 after that. I get the Motorcrat Mercon LV from Rock Auto for $60, delivered, for a case of 12, $5/qt. It's so easy to do a d&f with this transmission. And since I started doing d&f's early I should avoid having worn fluid and junk floating around and clogging the internal filter. Thanks for sharing your experience with Maxlife, after the warranty that's worth keeping in mind.
Whimsey
