45526 Members
64 Forums
193825 Topics
Max Online: 2449 @ 05/13/13 01:57 PM
#1855050 - 04/12/10 05:48 PM
5 different Subaru filter options - cut open pics
Loc: Ottawa
08 Forester 5mt, RT5 10w30, PSL14612 OF, P1 AF 10 Corolla auto, VWB 5w30, Fram OF, Fram AF 196cc CPE, 208cc LCT, Honda GCV160; *all* Rotella T5 10w30
#1855053 - 04/12/10 05:50 PM
Re: 5 different Subaru filter options - cut open pics
[Re: webfors]
Formerly DT466E_bus
Loc: USA
That fram looks great.
They all do.
2010 Lincoln MKZ 23,500 miles
Formerly DT466E_bus
#1855063 - 04/12/10 05:57 PM
[Re: Andrew MKZ]
Loc: michigan
#1855067 - 04/12/10 06:02 PM
[Re: webfors]
Loc: N.H, U.S.A.
Thx, WEBFORS, I can smell the clean, crisp Canadian air blowing right through those photos! The wix/napa cartridge looks tiny, and the 51356 is the larger one for ACURA, Nissan, Mitsu application IIRC? I'm stuck with the SOA OEM 12A blue fram cans till warranty is up; if the car wasnt knocking and I wasn't worried about throwing a moving part out of the engine, Id run something else
2012 Honda Fit Sport 5MT, OC#4 13,7kmi-QSUD 0W20SN+WIX 57356 Filter 2011 Forester 5MT 5Door, OC#6 42Kmi-QSUD 0W20SN+TokyoRoki 130 Filter
#1855069 - 04/12/10 06:04 PM
[Re: webfors]
Loc: Ottawa
#1855079 - 04/12/10 06:10 PM
[Re: webfors]
Loc: Ottawa
I'll be honest, I was more impressed with the spec'd filters (the QS and Tokyo Roki). They were very well made, lots of solid even pleats and no sign of degradation.
By looking at the pics above, it's hard to make an argument in favor of a larger/longer filter when the smaller ones appear to have just as much, maybe even more, media. The small height of the Tokyo Roki and the QS (aka Purolator Classic) and tight even pleats makes for very sturdy filter media. I was expecting less from the Classic and was expecting the Tokyo Roki to be a much better filter. When in fact, they are very close and I would choose one or the other depending on price. Since the P Classic is the only available of the two (The roki is discontinued), and the fact that it's much less expensive, would win my vote of all the filters in the line up.
#1855092 - 04/12/10 06:18 PM
[Re: chad8]
Loc: Ottawa
Only if you want to be super awesome like me!!
#1855099 - 04/12/10 06:22 PM
[Re: ARCOgraphite]
Loc: Ottawa
Thx, WEBFORS, I can smell the clean, crisp Canadian air blowing right through those photos! The wix/napa cartridge looks tiny, and the 51356 is the larger one for ACURA, Nissan, Mitsu application IIRC? I'm stuck with the SOA OEM 12A blue fram cans till warranty is up; if the car wasnt knocking and I wasn't worried about throwing a moving part out of the engine, Id run something else Nothing wrong with the Napa gold. It's a very well made filter with lots of tight pleats. The P Classic 14610 and PH7317 are definitely taller than the Napa gold, so if I had to choose one of the three it would be the P Classic. But in the Subaru application you get to use these smaller filters like the Roki and P Classic 14612 which appear to be very well made, and IMHO I would choose them over the taller "oversized" options.
#1855130 - 04/12/10 06:39 PM
[Re: webfors]
Loc: Virginia, USA
Wow, that pipe cutter did a great job. Any trouble with it? I may need to pick one of those up. All the filters look fine to me. I continue to use the Honeywell 15208AA12A on my Forester. They do great too. Did you notice any different sounds or vibrations between all of them with cold start-ups or normal operation?
#1855138 - 04/12/10 06:42 PM
[Re: webfors]
Loc: Michigan
I like the Tokyo Roki the best out of these. Appears to be very well assembled.
2002 Chrysler PT Cruiser Limited GC 0W-30
#1855142 - 04/12/10 06:46 PM
[Re: drewjp]
Loc: SoCal
I like your tool! Where can I get one?
04 Ram 22,000 QS 5w30 13 Hyundai Sonata QS fact 05 Mustang Conv Oriel Syn 5w30 06 Solstice 22,000 NAPA Syn 5w30 06 Tahoe 70,000 Val semi 5w30
#1855194 - 04/12/10 07:19 PM
[Re: mrfish]
Loc: Ontario Canada
Home Depot, plumbing dept.
2001 Corolla
#1855195 - 04/12/10 07:19 PM
[Re: mrfish]
Loc: New York
What, no PureOne PL14610 or PL14459? I like the silicone ADBV and the better media.
#1855628 - 04/13/10 05:54 AM
[Re: Soobs]
Loc: Ottawa
Wow, that pipe cutter did a great job. Any trouble with it? I may need to pick one of those up. All the filters look fine to me. I continue to use the Honeywell 15208AA12A on my Forester. They do great too. Did you notice any different sounds or vibrations between all of them with cold start-ups or normal operation? The new pipe cutter is easier to use than the two 'oil filter cutters' I've purchased over the past year. Cost was $40 with a lifetime warranty from Canadian Tire since it's a Motomaster product. I noticed no difference in engine operation with any of the filters, except the Fram and Napa, since neither of those have been used by me. The Fram came off the Honda Civic belonging to a friend. The Subaru OEM filter made by Honeywell appears to be well made. However, I can buy the P Classic for $4 in Ogdensburg (upstate NY), so I'll most likely be buying a stash of those on my next trip over the bridge
#1855629 - 04/13/10 05:56 AM
[Re: drewjp]
Loc: Ottawa
I like the Tokyo Roki the best out of these. Appears to be very well assembled. Agreed. It is the filter that impressed me the most. The depth of media, number of pleats, bonding, etc. And it was the smallest filter of the bunch. So it's impressive that Tokyo Roki could fit that much filter in such a small can.
