Whew!
Here are some of my questions - Please bear with me...
First, I must preface my questions with the comment that the scheduled maintenance guide for my new 2006 Tundra is actually for the 2007 model. The salesperson said they ran out of the 2006 maintenance guides. Since I just bought the truck yesterday, I suppose that's a plausible explanation. The salesperson swore up and down that there is ZERO difference between the 2006 and 2007 guides. So - For those of you that have the 2006 Tundra Maintenance guide, let me know if any of my questions below seem to contradict what is listed in your maintenance guide....
With that said, here are my questions:
1) I notice there is no longer a separate maintenance schedule for normal vs. severe conditions. It simply recommends oil changes every 5,000 miles or 6 months for all conditions, whichever comes first. I am somewhat surprised at this - considering the V8 model I have has a 6.5 quart capacity, this seems unusually conservative. Obviously, I will follow this closely while the car is under warranty. I've been using Mobil 1 EP 5W-30 in my Lexus, which has a very similar 4.3 V8 engine. But with only 5,000 miles for an oil change, I am thinking regular Mobil 1 5W-30, or perhaps Mobil 1 Truck and SUV 5W-30 might be more appropriate. I don't care about the cost difference between the EP version of Mobil 1 and the regular version - But I am wondering if there is any advantage of using the EP version over the regular version of Mobil 1 under such a short change interval. Comments?
2) I do not see any change recommendations for the ATF except under special circumstances. The ATF used is the WS standard - I've heard of this discussed before. It seems every car these days are recommending proprietary fluids. Does anyone besides Toyota make fluid meeting the WS standard? Note that in general, I'm not particularly fond of the "Universal" ATF fluids that claim to meet every concievable standard out there. What is different about the WS fluid? How expensive is it? Also - I didn't see a dipstick for the ATF while I was under the hood, although I may have missed it - But I don't see it shown in the owner's manual either. Is this one of those vehicles that has no dipstick for checking the ATF? This worries me....Do any of you other Tundra owners still change your WS ATF? If there is no dipstick, how do you tell how much to put in? (And where do you put it in)?
3)For standard differentials, the owner's manual recommends Hypoid Gear oil API GL-5. But for a Limited Slip Differential (which I DO have) it says, "Hypoid Gear Oil for limited-slip differential API GL-5." This implies to me that there is a difference between different GL-5 oils - In other words, the oil has to specifically be suitable for Limited Slip Differentials. Will Mobil 1 Gear Lube work in my case?
4)The viscosity for the LSD says to use SAE 90 above 0 degrees F. At first, I figured I could just use Mobil 1 75W-90 for this. But: They already recommend 75W-90 for the standard differential - if 75W-90 would work in the LSD, I figure they would list it. Is there some reason I should use a single weight SAE 90 for the LSD? If there is, who makes a synthetic single grade SAE 90?
5) For lubrication of "Spider" propeller shafts, it recommends "Lithium base chassis grease, NLGI No. 2. For the "Double cardan joint", it says to use a Molybdenum-disulphide lithium-base chassis grease, NLGI No. 2. For the slide yokes, it says either type of grease is Ok. First of all, I do not even know these different kinds of propeller shaft terms - What is a spider, a double-cardan joint, and a slide yoke? Can I use the same grease for all these, or do I really need two kinds of grease as specified above?
Sorry for all these questions - But since I've driven nothing but 4-door sedans for the past 30 years, I'm not very familiar with the maintenance needs of light trucks....
