Prestone's flushes use citric acid (sodium citrate). I agree with LT4 Vette - if there's no sedimentation or scaling, chemistry's not necessary. I do recommend flushing with clear water (preferably distilled water - it's cheap at WalMart) until the effluent drains clear. Keep your heater valve pegged on the "Hot" setting to flush the heater core and idle the engine until it warms up to normal operating temperature between drains. You can judge this by how hot the upper radiator hose is - it'll be H-O-T once the thermostat opens. Since even opening the block drain plug(s) won't entirely drain remaining water, use an antifreeze concentrate instead of 50/50 premix. Then adjust the concentration with distilled water and one of the coolant hydrometers (Prestone or Victor come to mind) to establish a verified 50% (or whatever percentage you prefer for your climate) concentration. Time consuming and boring, but at least you'll know it was done right when you're finished. (and you won't have to wonder if any of the flush chemistry remained behind to screw up the new coolant's pH and corrosion inhibitors)
