Many riders get into a vicious circle of overtighteneing their chain, which causes stretch, which require another tighten, so on and so on. Often the spec for min chain tension (wht the the guys caught in the circle use) is TOO tight. I've verified this many times by removing the shock and positioning the swingarm to it's tightest position. At this point it's nice to see about 3/4", many oem min specs I've found banjo string tight. Is it possible the confidence gained by the scott oiler may have been enough to keep the riders from constant dinking around with the tension? thus the longer chain life?
