Update:
I drove out straight to Florida on the night of the 23rd, Getting to florida the afternoon of the 24th.
In ECO I averaged 39MPG, handling was good, uphills were a breeze, the only issue was the road noise in Louisiana on I10/I12 (Bless you folks who drive those roads)
The car did not use a drop of oil on the way there.
Coming back was a bigger trick as I came back on the 30th into the 1st, which turned out to be a 27 hour drive versus a normal 17 hour drive, as I was going through Lafayette at the wrong time, and averaged 20MPH for a few hours on I10/I12 (also had acquired 12 bullfrogs and 3 catfish in my grille, when it rains, it rains in Louisiana)
The water handling was amazing, not sure if its the car or the 18 in Kumho Solus tires that came with the car.
I only averaged 35MPG on the way back, though a lot was stop and go.
Did not use a drop of oil the entire trip, dipstick appears clean with no traces of metals on it.
The gasoline used during the trip was Loves station Premium. the gasoline used while in florida was either Citgo Ethanol Free Regular or Exxon/Mobil Regular Grade
I will be changing factory fill tomorrow,
the car was driven in cruise control with eco on, with occasional eco off sport mode shifting (Steering Paddle shifting, as well as floor shifting)
The only hiccup I had was hard shifting on a high grade hill in N Florida, where the CEL blinked momentarily,
overall, a nice drive with bad moments. Nothing that was the cars fault, more environmental factored.
I now sit at 3465 MI, I feel as the car will last a lot longer than that!
