Originally Posted By: bobbydavro
Originally Posted By: fpracha
you are making this interesting now... can you show some proof or UOAs where PMA containing xW-20/30 oils have sheared more than the older VM technology oils ?
Otherwise why on are PMAs the more costly VM today ?
PMAs give FE benefits but require much higher treat rates, they also don't perform that well in high temperature oxidation tests.
No data I can share, but PMAs high treat rate and high SSI is the reason for shear, hence they only really get used in low visc 0W-20 / 0W-30s. Anything higher will need a combination of VMs if you want PMA in there.
Once again bobbydavro is 100% wrong.
The very high VI polymethacrylates (PMA) polymers used to formulate the ultra high VI 0W-20 oils such as TGMO, MGMO and Sustina actually use a lower treat rate than the typical copolymers that are more commomly used in most lower VI motor oils.
Infineum calls their new PMA polymer "SV Star" for it's star-like molecular structure.
Lubrizol calls their new start-like PMA "Asteric".
Evonik also have a very high VI PMA.
The new PMA polymer technology was discussed in the following thread:
http://www.bobistheoilguy.com/forums/ubbthreads.php/topics/3063326/1
