With this wonderful spring weather rolling through (2-5in of fresh snow) it has me thinking about my summer car projects; most particularly on the Mustang. The two main projects I plan on doing is dropping the trans to replace a contaminated clutch disc and replace the input shaft seal, and also I wanted to repack the trac-lok clutches and replace my 2.73's with 3.73's that have been sitting on the shelf for YEARS.
Not sure if I really want to dedicate THAT much time to car work this summer, especially since I'm sure other issues will come up with this or other vehicles in the fleet. I know I can handle the clutch work, although actually moving the trans in and out of position will be tough since I have minimal help... And I know the trac-lok clutches won't be an issue either but I'm a little hesitant about the gears. Its something I really want to do myself for the experience, especially since I anticipate this car being "extra" during the summer. But of course, its so easy to screw it up.
Figure the clutch work will likely end up spanning 2-3 days and I would anticipate the rear end work taking a little more time then that since I'll need to pop into a shop to have them r&r the pinion bearing. Since the car has higher miles I'm very tempted to do new pinion and carrier bearings while I'm in there, but at the same time my plan is to TRY it with the original shims first and see how it all measures out...
Any thoughts? I've done a lot of reading about rear end work and it definitely looks do-able... just not sure if I *want* to go through that much...
