Originally Posted By: Garak
Originally Posted By: jaj
I guess you must mean the weather - the forecast is for sun and 50+ degree weather next week ;-)
I'm talking the general feel and attitude.
Gasbuggy: If they can be expected to use specified oil and capacities, which aren't always posted somewhere on the vehicle, they can handle more than, "See you in 3000 miles." If they can't they're in the wrong business. I appreciate that it's difficult to get everything correct in a few short minutes for a few dollars, but that's the nature of the beast.
It's not the nature of anything, aside from this being the nature of nanny state. As a BITOG'r you should know that putting long suggested change intervals in from the manual will lead to more engine wear and possibly sludge and other damage for consumers. Do you agree that it will lead to some drivers ignoring their OLM and defaulting to the sticker/shop suggestion? Yes/No. Do you agree that factory recommendations can fall short of protecting the engine? Yes/No. Do you agree that some oils will fall short of blindly meeting a mileage spec? Yes/No. Do you believe these blasphemous short interval suggestions save a portion of inept non oil level checkers from engine failures? Yes/No.
For this bill to make sense the answer to all should be No. California wants to stick it to shops and try to prevent more waste oil from being recycled. It's the ignorant consumers they're supposedly protecting who will also be the ones suffering. Perhaps they need a bill that makes it illegal to run past the mileage recommendation or to not maintain a safe oil level in your engine, that will solve some of the new problems this creates.
This is idiocracy all around. They will have countless different model years with identical engines running the same oil and receiving varying change recommendations based on the manufacturers suggestion for that given year. Hopefully the bill allows shops to opt to make no suggestion, and let the consumer figure it out, rather than be forced to provide one and accept liability for what may occur from making it.
